SUJET : Goldring G65 tonearm
Goldring G65 tonearm 26 Avr 2017 22:00 #1
Je m'interesse à ce bras.
Fabriqué et vendu par Goldring, il était aussi monté sur les GL68.
Je suis en train de chercher de mon côté, mais si quelqu'un a des infos, ou en possède un, ça m'intéresse.
Goldring G65 tonearm 26 Avr 2017 22:03 #2
Colin admin LH écrit:
The G65 arm as fitted to the stock GL68 is mounted at 225mm from the spindle. This gives excessive overhang imo, with a typical cartridge mounted in the fixed screw holes (ie no adjustment) the effective length is approx 247mm, that is an overhang of 22mm - I would have expected an overhang of about 12mm - 15mm. The G65 arm was sold separately but I have never seen the manual so I don't know if Goldring suggested 225mm as the correct dimension for mounting the arm.
Because the cartridge cannot be adjusted in the headshell, I would create a slot allowing the spindle to pivot to be adjusted from 225mm to 235mm.
www.rewindmuseum.com/vintageturntable.htm
The GL 68, incorporate the new G.65 arm. This is of low-mass tubular construction with sliding
counterweight, Swiss manufactured precision motor. Click-in positions for the 4 standard
record speeds. 12" diameter turntable. The turntable was reviewed in the May 1966 issue
of the Gramophone magazine. The price was 16 pounds and 16 shillings (£16.80) in 1966.
A Goldring cartridge added about £5.00 and a plinth and cover added a further £10.
this made the whole unit about £32 in a ready to use condition.
When most people look back on the 1960s and early 1970s they remember the very popular
GL75. Indeed the GL 75 was deployed in a number of Hi Fi units / "radiograms"
from various manufacturers (including "Leak") at the time. The GL 68 is
probably less well know, but that makes it more interesting to a museum.
See the "HiFi News" article below from August 1965
Goldring G65 tonearm 27 Avr 2017 16:06 #3
Bon ... ben ... on va voir à la réception ... :oops:
Goldring G65 tonearm 28 Avr 2017 23:37 #4
Je ne connaissais pas ce bras.... jamais vu °o)
Il a une bonne gueule, hâte de la voir en détail.... :ok:
Goldring G65 tonearm 28 Avr 2017 23:55 #5
Il est parti aujourd'hui.
Je voulais le mettre sur la F50 pour remplacer le bras mono ... mais vu que la B51 a le même bras en stéréo, je pense mettre celui de la B51 sur la F50.
Du coup ... un bras en trop ... je le mettrai sur planchette ... ou je me cherche une autre 50 ... ?
Il a une chouette gueule, je trouve aussi, j'aime son tube et son pivot horizontal avancé.
En plus il est rare et c'est du Golring (pas du lenco), donc moins de scrupules ... :)
Goldring G65 tonearm 02 Mai 2017 21:57 #6
  • mulanee
  • Portrait de mulanee
  • Remerciements reçus 4
Que faut-il comprendre?
(voir ma signature)
Goldring G65 tonearm 03 Mai 2017 18:58 #7
C'est essentiellement une private joke à l'attention (essentiellement) de JG (mais maintenant je te comperai dans le lot ... :mdr: ).
Je plaisante souvent sur les bencos, et j'accepte le retour sur les gerards.
Comme je lance des piques sur les bencos, je ne pouvais pas en toute honnêteté intelectuelle, m'offrir un bras lenco.
Donc heureux que ce soit un goldring ... je n'ai rien contre les lencos, la preuve, j'en ai.
Mais cette susceptibilité m'amuse (coupable ! votre honneur) et me pousse souvent à aller un peu loin, je l'avoue.
Mais ce ne sont jamais que des "mots" ... ;)
Goldring G65 tonearm 13 Mai 2017 03:06 #8
Reçu ce matin, déballé à l'instant ... intéressant !
J'aime sa conception.
Photos demain ... :)
Goldring G65 tonearm 16 Mai 2017 13:57 #9
Goldring G65 tonearm 16 Mai 2017 14:01 #10
Goldring G65 tonearm 19 Mai 2017 12:46 #11
Je n'en avais jamais vu! Il a une bonne gueule.
Goldring G65 tonearm 20 Mai 2017 00:56 #12
Allègement de bras de conception antérieure pour s'adapter aux cellule à compliance plus élevées (Lenco pratiquait l'axe vertical déporté depuis longtemps). Début de la démocratisation d'une pseudo hi fi et du bas de gamme clinquant. Grosse tête carrée sur corps fluet, fixation de cellule aberrante. Contre poids sous capot léger.
Je me demande ce qui vous séduit .... Si c'est l'esthétique je préfère celle des bras généralement plus anciens ou 10-12 ans plus tard.
(mode grincheux ce soir -(8)- )
Goldring G65 tonearm 20 Mai 2017 11:27 #13
Ah le grincheux (TN the Grinch).
A ma connaissance Lenco est né en 1947.
Leur première platine de conception propre est la F50 (1956 ?).
Edit: "trouvé" depuis le modèle D45 entrainement direct 78t datant de fin 40's.
Bref, tout ceci pour:
- Soit, dans ce cas peux tu m'indiquer de quel bras il s' agit, je ne connais pas tout de Lenco, c'est certain, j'ai du louper un truc ... merci !
D'autant plus que les bras à pivot déportés m'interessent beaucoup ... ;)
- Sinon, comme précisé au début du sujet, ce bras date de 1966, et c'est un Goldring, rien à voir avec Lenco.
Goldring était l'importateur UK des platines Lenco, ils avaient déjà placé un de leur bras sur la F50 et la L70.
Goldring est aussi à l'origine des 88/99.
* pour ce qu'indique Collin l'admin LH, au sujet de la longueur effective et du placement sur un châssis Lenco B, j'ai idée que cela ne peut en fait que fonctionner qu'avec certains corps de cellule (Goldring ... au hazard ... :) ).
* sinon, bingo, c'est bien le look old school qui m'a séduit en plus du pivot déporté.
C'est plutôt un bras lourd.
Le pivot horizontal semble de très bonne facture, pièce très lourde, aucune critique quant au tube, semble rigide (résonnance à tester).
Pour le reste tu as sans doute raison.
PC plastique non ajustable (mais si construit pour un type de cellule précis peut se comprendre).
Quand aux histoire de compliance, on verra à l'usage, il y a tellement de contre exemples.
Et oui, tout à fait, ce n'est sans doute pas du hdg, après tout, c'est juste du Goldring ... et c'était placé sur une B52 à l'origine ... :mrgreen:
Goldring G65 tonearm 20 Mai 2017 15:40 #14
En y réfléchissant, je me suis dit que tu pensais au bras des F50/B51.
Un bras que je trouve très bien en fait.
Soit, c'est vrai qu'il a un pivot déporté, mais réglage par ressort.
Je pensais à un bras balancé.
Mais tu as raison, ce bras n'a pas équipé les premières F50, mais il date à peine de quelques temps après leur sortie.
L'avantage des pivots déporté, comme les bras à ressort, c'est que rien ne dépasse au niveau du châssis, pratique pour les capots et electrophones.
Donc ouais ce G65 peut être comparé au bras de F50, une version moderne pseudo HiFi (?).
Goldring G65 tonearm 20 Mai 2017 21:20 #15
Tout à fait. Le bras des F50; Vers 1956 je pense aussi car il y avait une F50 dans ma famille cette année là. (j'avais 7 ans , j'étais déjà occasionnellement grincheux).
J'ai conservé le bras. Pour y remettre un jour peut-être une GE VRII. Mais elle va tellement bien sur le DA 308 ... (et pb de lift à ajouter)
VTF à ressort: je pense que c'est une technique liée à des bras lourds, pas à l'axe déporté. Mon Ortofon RMG212 combine les deux procédés, ressort + contre-poids. Peut-être parce qu'il est nettement moins "masseux" que le Lenco. Encore que le déport crée un contre-poids.
VTH uniquement à contre-poids ç'est venu avec les bras de masse faible ou moyenne. Question masse, le Lenco des F50 ce doit être bien haut.
Goldring G65 tonearm 20 Mai 2017 21:26 #16
N'empêche que le bras des F50 (a-t-il un nom ?) est vraiment pas mal (surtout pour l'époque), et surtout si on le compare à un BOB.
J'aurai une 134 en spare, je n'hésiterai pas, je tenterai la greffe ... ;)
Temps de génération de la page : 0.130 secondes
